Jan 3, 2010, 6:29 PM
Post #4 of 5
(2462 views)
Re: [suzukiray] Mitsubishi 65907
Inside the TV on the circuit boards are things called "parts". Each part on the board is assigned a "Location" number that is stamped/silk screened onto the top (and/or bottom) of the board. You may have to carefully rearrange the dust to enable you to read these numbers. Simply match the location number assigned to the part in question. If necessary, "Google" the part you are attempting to find (ie, "fuse"), choose "image" and you should see many pix of the many types. Alternatively, visit a parts site like Digi Key or Mouser, they have pix of many types of fuses. ------------------------- Location: Far, Far Away
