blue and yellow lines
alisonladyh
Mar 8, 2006, 12:40 AM
Post #1 of 2 (3726 views)
blue and yellow lines Can't Post
Hi, hope somebody can help me. I have a Phillips Rear projection HDTV Monitor. PP9202 Yesterday, bright blue and yellow lines and outlines appeared on the bottom and top right of the screen. Writing is doubled as well. Do you think degaussing would help, or do I have to shell out $$$$ to a repairman. Is it anything to do with the electron gun or convergence. The TV is about 3-4 years old Unsure
TV Pro
Mar 12, 2006, 6:31 AM
Post #2 of 2 (3707 views)
Re: [alisonladyh] blue and yellow lines [In reply to] Can't Post
Ho brother you have the most comun problem on the rear proyection that you can imagen.
You have a convergence problem & need to repalce the convergence IC's & also refind if any of the resistors are open before you put them to work I think (you must check on the convergence board it use STK 392-110 they are the bigest IC located on the left board attached to a big heat sink
Good Luck
