Larry E
Aug 25, 2006, 12:50 AM
Post #6 of 13
(8769 views)
Bob, re-check the HOT c-e to see if it is shorted again, if not, check your B+ voltage from emitter of HOT to collector of Hot, negative lead of voltmeter to emitter, positive lead to collector, should be around 135 volts, if it comes up to say 70-80 volts and then slowly decays, remove the HOT from the board and then hit power again and see if the B+ stays up on the collector trace, if it does you probably have a bad flyback, Larry E
