Larry E
Aug 10, 2005, 11:54 PM
(2201 views)
Re: [firesnatch] mitsubishi compatability question
Hi, No you can`t swap the boards from those two models, some individual parts such as resistors, diodes, caps are the same but the boards are NOT the same, the only way you can check compatibility between 2 models would be to buy the service manual for each model and then check part numbers to see if they are exactly the same number, Larry E
