toshiba 50h95 no power
broketv
Oct 24, 2007, 11:31 PM
Post #1 of 3 (3532 views)
toshiba 50h95 no power Can't Post
I had a convergence issue with my toshiba 50h95. I installed new sanyo IC chips and now the set tries to turn on but wont, then the light on the front just flashes. No sound no picture. When first turned on it clicks once and sounds like powers up for a second but then nothing. I checked the connectors I unplugged and rechecked my solder connections. Look ok. Could it just be a poor solder job?
Repair man
Jun 13, 2008, 9:50 PM
Post #2 of 3 (3366 views)
Re: [broketv] toshiba 50h95 no power [In reply to] Can't Post
These sets are bad for cold solder joints near the ICs you changed, you may have disturbed them while replacing the ICs. Some of these sets also have 3.5 amp pico fuses that open; the fuses are often on the other main board (not the convergence board) they are towards the front of the chassis near the middle. There are two of them side by side that provide voltage to the ICs. If you have a meter you can unplug the set & check the fuses for continuity. The fuses I'm referring to are often small black rectangular shaped fuses I don't recall the part number on the board. There are also a few resistors near the ICs that sometimes go high in value or open. they are larger 1 or 2 watt resistors & are usually around 2.2 ohm resistors; the values will be marked on them, again if you have access to a meter you could check the value of these resistors. These set are also real bad for the plastic supports etc. that hold the chassis gets very brittle so handle it with care.
________________________
Learn Plasma TV Repair
_________________
Learn LCD TV Repair
Chrisry696
Oct 15, 2008, 1:49 AM
Post #3 of 3 (3234 views)
Re: [Repair man] toshiba 50h95 no power [In reply to] Can't Post
Are you saying it would work before you got into it, just the convergance was off? If so, then you did something wrong. Check for connectors/wires that may have come off when pulling on the board. I hate to say this, but most people don't know how to solder, so check your work with a magnifing glass. Remember, it worked before, so chances are you did something. It happens to me too and I always have to "check my work" before going off on a tangent looking for something else. Good luck.
