SONY DAV-SC8
KAKU
Apr 8, 2006, 2:11 PM
Post #1 of 4 (2744 views)
SONY DAV-SC8 Can't Post
I HAVE ONE OF THESE UNITS AND LOTS OF PROBLEMS WITH IT. WILL NOT COME OUT OF STANDBY AND WHEN IT DOES WILL NOT ACCEPT DISCS, WILL SELECT ALL THE OTHER INPUTS AND I HAVE SOUND ON ALL CHANNELS,HAVE DISCONNECTED THE SUPPLIES TO THE DVD DECK AND THE PROBLEM IS STILL THERE. ANYBODY OUT THERE. THANK YOU
denonjapan
Sep 23, 2006, 3:57 PM
Post #2 of 4 (2667 views)
Re: [KAKU] SONY DAV-SC8 [In reply to] Can't Post
You said: "HAVE DISCONNECTED THE SUPPLIES TO THE DVD DECK AND THE PROBLEM IS STILL THERE" >too bad "CLEO" is out of business!Sly
denonjapan
made in japan
KAKU
Oct 1, 2006, 2:29 PM
Post #3 of 4 (2637 views)
Re: [denonjapan] SONY DAV-SC8 [In reply to] Can't Post
WHAT I MEANT TO SAY WAS AFTER DISCONNECTING THE SUPPLIES TO THE DVD DECK I AM STILL STUCK WITH THE INTERMITTEWNT STANDBY PROBLEM. THE UNIT HAS GOT A MIND OF ITS OWN AT TIMES IT WILL FIRE UP OR WILL NOT
(This post was edited by KAKU on Oct 1, 2006, 2:30 PM)
denonjapan
Oct 6, 2006, 2:14 PM
Post #4 of 4 (2622 views)
quote:'THE UNIT HAS GOT A MIND OF ITS OWN AT TIMES IT WILL FIRE UP OR WILL NOT'...I do understand what you mean however doesn't ring a bell to conclude the unit exibited electronical problem which you said it does work and will remain on standby. Try to unplug the unit for a while, avoid using too many remotes around it at the same time!
denonjapan
made in japan
