Crumbtrail TV Forums: TV Equipment: Digital TV Forum:
Panasonic digital tv
Stuart js
Sep 16, 2005, 11:34 PM
Post #1 of 4 (3408 views)
Panasonic digital tv Can't Post
Any Ideas?
I bought a new Panasonic TV recently and it turns itself off then back on again, I had the first TV replaced, by recomendation of panasonic, now the replacement is doing the same, after a while, it will just turn itself off then back on again. I am running the TV set from a boosted 'normal' anologue ariel, signal strength is excellent, is this a common fault. the model number is TX28dtx11.
regards
StuCrazy
Stuart js
Sep 26, 2005, 9:04 PM
Post #2 of 4 (3368 views)
Re: [Stuart js] Panasonic digital tv [In reply to] Can't Post
Update - Problem sorted,
I bought a Sony DVD recorder at the same time and three TV's later found out that Smartlink and Qlink are not compatable!!! the DVD recorder was telling the Tv to swithch off!!
Quick fix - for now - put the scart lead (TV end) into the s-video socket instead of how shown in the sony booklet. when using it with a Sony DVD recorder.
hope this helps someone.
regards
Stu
mikehibbert
Sep 27, 2005, 10:35 AM
Post #3 of 4 (3361 views)
I have the same problem. I am now on my second TX28dtx11 and it has the same problem, it drops into standby and then back on again about once an hour. Looking on the internet it seems to be a common problem. I suggest getting your money back and buying a different telly. From what I've read it is a hardware problem on one of the circuit boards.
SimonW
Oct 5, 2005, 6:57 AM
Post #4 of 4 (3333 views)
Re: [mikehibbert] Panasonic digital tv [In reply to] Can't Post
Hi, I also have a Panasonic TX-28DTX11 hooked up via SCART to a Sony RDR-HX510 DVD / HDD Recorder. My TV (I'm on my second one) also switches itself into stand-by, and then back on again at intermittent intervals. So, is it a problem with the TV? Or the Sony DVD / HDD?
