Crumbtrail TV Forums: TV Equipment: Digital TV Forum:
Sound Problem
pale_kid
Feb 1, 2010, 10:40 PM
Post #1 of 4 (2823 views)
Sound Problem Can't Post
Hi all, <br> <br>I have recently moved into a flat, and have found that my digital tv signal had intermittent sound and maybe every ten minutes or so (on some channels) the picture would freeze, then go green, then reset to whatever channel was on when the tv was turned on. <br> <br>I researched this problem, and found out that it was most likely due to the need for a signal booster or attenuator. as i didn't know which i needed, i bought a device that does both. with this device attached, the picture is fine, but the sound continues to beintermittent on some channels. i have adjusted the device to various degrees of amplification/attenuation, but nothing seems to help. <br> <br>the tv is a philips 32PW9527 (in case that matters). <br> <br>i would really appreciate any help. <br>thanks. <br>
(This post was edited by pale_kid on Feb 1, 2010, 10:41 PM)
denonjapan
Feb 3, 2010, 5:34 AM
Post #2 of 4 (2804 views)
Re: [pale_kid] Sound Problem [In reply to] Can't Post
Re-locate the tv.
denonjapan
made in japan
JohnRocks
Apr 9, 2010, 4:56 AM
Post #3 of 4 (2759 views)
It may be the problem of voice modulation. Set out the frequencies.
Rackmount LCD Monitor
USB KVM
pale_kid
Apr 9, 2010, 10:13 AM
Post #4 of 4 (2755 views)
Re: [JohnRocks] Sound Problem [In reply to] Can't Post
thanks,
what do you mean by "set out the frequencies"?
