philpense
Jun 1, 2012, 3:57 PM
(1993 views)
Digital Antenna Project
Looking to make a project out of a broken TV antenna… the coaxial into it is severed. There are a number of DIY videos on youtube that suggest better results that some commercial products. I have a digital converter box for over the air digital programming and have generally had good reception. A common solution is a coil. I’ve made a prototype and would ask the following: - Is a coil a plausible solution - The gauge of the wire, the circumference of the coil, the number of coils per inch… I suspect that each could affect reception. Is there and guidance on this? - The coax connects to a circuit board… Looking for the best way to reestablish a connection to a longer stretch of coax going to the digital converter. I am an amateur but would want the best practice for reconnecting two raw ends of coax. I have images of the items uploaded to an online folder. https://skydrive.live.com/redir?resid=52B21D2F3F75A51A!1318 Much thanks in advance for an informed opinion
