TANK1
Apr 15, 2005, 1:21 PM
(2796 views)
Plasma are both High Def and Enhanced Def. Enhanced Def is High Def Lite. If you want a big floor model tv- Mitsubishi 55315 is 55 inches of tv. If you are at least 8 ft away you will enjoy this set.It is sold at Ciruit City,Best Buy and Sears. Another option would be a Samsung DLP set.You would need a stand for these sets. The good thing about a DLP is when the bulb burns out you just have it replaced and the set looks brand new again.These sets weigh less than 70-90 lbs and can moved easily. You might consider burn-in as a factor when deciding on a set.Burn-in is damage caused to your screen by a image on your screen constantly with the contrast too high.If you watch Fox news,CNN,or MSNBC,the ticker that runs across the bottom of the screen will cause burn-in.You must leave the set on for every long time on one channel with a ticker. Plasma and the big floor type rptv can get burn-in. DLP,LCD,LCOS will NOT get burn-in. Sony makes the LCD type sets. JVC has the LCOS type set.
