denonjapan
Apr 8, 2007, 6:40 AM
Post #3 of 3
(2240 views)
Re: [Lawnguy910] Plasma vs. LCD
I have no object on your choice, however when your mind clouds up your decision due to LCD's presence as alternate choice and not by VERSUS or by comparison. The two has it's own definition performance. Both displays in early years has overcome their common issues at least to date those new and upcoming models are now reached it's peak. On the other hand, LCDs now progresses the slow response issues down to undetectable screen performance regardless of noted nos. It don't really matter. Also, Plasma technology achieved to eliminate potential burn-in in most current models however, one should not ignore is: their gradual dimming process. This is certain to every single one of them. Your concern to why Plasmas do not possess a full 1980 x 1080i resolution is bec. Pixels count being permanent to Plasma screen can only obtain a full resolution thru it's built-in processors. Only if you are receiving 1980 x 1080 video materials. Also,The majority of you guys ignore the words:>CAPABLE DISPLAY from the very beginning. Let's start with EDTV High definition capable display. Regardless of broadcasting status, No one will experience what 1980 x 1080 really means if you have no materials to feed on full resolution displays. It don't mean anything... On the other hand, LCD's resolution can even go higher than a full 1980 x 1080 and that's possible thru it's moving molecules. does it mean better? It is by number, but not necessarily true by CHOICE. If your Monitor is HIGH DEF COMPATIBLE, That's essentially good enough. If this is your first buying experience on flat-screen, you can now rely on LCD but it's a matter of good choice. Not all of them are thesame. We don't always get what we want but you have to compromise with your needs and yes indeed, they don't make it in 50 inch but 57 to 60 there is. Take a good look of SHARP, NEC and JVC. Goodluck! denonjapan made in japan
