gefen scaler
hotrod351
Jun 21, 2007, 11:01 PM
Post #1 of 9 (2890 views)
gefen scaler Can't Post
i have a 32" samsung hd lcdtv. im hooked up to dish network and have two hd receivers. im recording off each receiver to a dvd recorder, ilo and liteon. im using rca and s-video connections between the hd receivers and then to a switch box that then uses rca cables to go to my tv. the recorded sick isn't all that clear, nowhere as clear the picture i get on the tv. im looking at the gefen scaler and wondered if anyone has tried one. i thought i could run my dvd recorders, each, into the scaler then use the hdmi cable out of it to the tv hdmi input. i know the recorders are recording clear but sending the signal from them to the tv is where i loose the clarity. any thoughts on this.
TANK1
Jun 22, 2007, 9:38 AM
Post #2 of 9 (2879 views)
Re: [hotrod351] gefen scaler [In reply to] Can't Post
RCA and S-video don't transmit/carry hd signals only component video, dvi,hdmi cables.
So try a different type cables before you buy a scaler.
hotrod351
Jun 22, 2007, 4:26 PM
Post #3 of 9 (2873 views)
Re: [TANK1] gefen scaler [In reply to] Can't Post
i didn't know that. well thats where i hitting a road block, the only inputs i have on the dvd recorders are rca. i have component outputs on the recorders but it doesn't seem to help the picture playback .
TANK1
Jun 22, 2007, 5:33 PM
Post #4 of 9 (2871 views)
Most dvd players you must push a button to engage the progressive scan ( 480 p ) feature.
hotrod351
Jun 22, 2007, 5:45 PM
Post #5 of 9 (2870 views)
i don't understand what you mean by push a button to engage the progressive scan.
hotrod351
Jun 22, 2007, 6:23 PM
Post #6 of 9 (2865 views)
i found out about progressive scan in the manual. i have to have the s-video hooked for it. ive already tried that and the picture is the same as the rca jacks.
denonjapan
Jun 24, 2007, 2:59 AM
Post #7 of 9 (2859 views)
Part of your statement:"i know the recorders are recording clear but sending the signal from them to the tv is where i loose the clarity. any thoughts on this".
hotrod, your connections are ok. However, you are limited when copying HD materials due to copyrights protection. Your recordings are based from S-VIDEO recording in a dvd recorder. Therefore, your recording became a dvd quality. It doesn't mean you should have same clarity from original HD material cause you have outputed thru HDMI or component throughout your dvd recorder. It doesn't work that way!.......Wait a litle more time till blu-ray recorder becomes available to you, It will record exactly what you see in it's built-in HD tuner.
denonjapan
made in japan
(This post was edited by denonjapan on Jun 24, 2007, 3:09 AM)
hotrod351
Jun 24, 2007, 7:13 AM
Post #8 of 9 (2855 views)
Re: [denonjapan] gefen scaler [In reply to] Can't Post
im waiting for the ps3 to come down in price. i did find out that by using component cables from the recorders to the tv its a little better picture. also the picture guilty is a little better on the dvd player with the component cables.
TANK1
Jun 24, 2007, 11:24 PM
Post #9 of 9 (2850 views)
To engage the progressive scan ( 480p instead of 480i) you need to push a button on either the remote or the dvd player. If you want to fast forward - you need to push the fast forward button.
