Hello.
danielsoy
Jun 25, 2014, 2:03 AM
Post #1 of 15 (5970 views)
Hello. Can't Post
Hi ppl, this is my first post.
Would like to know if i may ask a question about
a LCD PC monitor (not tv) repair.
Thanks.
Jun 25, 2014, 2:49 AM
Post #2 of 15 (5967 views)
Re: [danielsoy] Hello. [In reply to] Can't Post
Sure. Why not?
danielsoy
Jun 25, 2014, 11:02 PM
Post #3 of 15 (5952 views)
Re: [jts1957] Hello. [In reply to] Can't Post
Ok , thanks JTS.
This is a Samsung monitor SyncMaster 2233 that shows frozen video of a moving image by just a second, and then goes dim.
So I can see just a frame by a second, when i watch a movie for instance, then the screen stays white, but image fades away and don’t return.
When i turn monitor off, and then on again, or if I change PC video output, from internal to external , get the same effect .A frame that last a bit, and fades.Like this:
https://www.youtube.com/watch?v=8ZGTuNltrnA
I cleaned up a cockroaches nest over the main board ,that was a lil rusty.
Power supply voltages, are ok and without ripple .X-tal is oscillating
at 12mhz.
Is it possible, by connecting my scope to the main board output that goes to de LCD flexible wire, to confirm if is the LCD panel, or the main board the part at fault?
Jun 25, 2014, 11:40 PM
Post #4 of 15 (5950 views)
It's also upside down.
Computer is set to output the correct display parameters/resolution?
Does it do this on DVI & 15pin?
Does Self-Check feature work properly?
Do you have the Service literature?
(This post was edited by jts1957 on Jun 25, 2014, 11:59 PM)
danielsoy
Jun 26, 2014, 2:24 AM
Post #5 of 15 (5942 views)
It was easier take the video with monitor upside down, cause monitor was opened in that position ,but image its not inverted indeed.
Screen config is ok.
Input is VGA(theres no DVI).I have Hsync ,Vsync And video input on that connector and in the microprocessor pins.
Did not try to access to service mode .
Got service manual of another monitor similar to this one.
I can see something like a video signal at 60hz, on the flex wire connector pins that goes to the LCD panel.
And setting scope to 20nsec, there is something like a clock on the clkm and clkp outputs.
Service manual says that LCD panel is broken, but I´m not sure...
Video n clock signals oscillogram is uploading.
https://www.youtube.com/...amp;feature=youtu.be
Jun 26, 2014, 3:34 AM
Post #6 of 15 (5940 views)
What is full model number?
What is similar Service manual number?
Scaler PCB is at one end of the LVDS cable, the other end usually plugs into a PCB that is part of the TFT display. There is sometimes a small surface mount fuse for 5V line on this board that opens.
from User Manual ...
Self-Test Feature Check:
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or
damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer
and the monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly.
danielsoy
Jun 26, 2014, 3:33 PM
Post #7 of 15 (5934 views)
Model is:
Front :Samsung Syncmaster 2233
Back cover sticker:LS22CMYKFNA/ZB11329
Service Manual:
http://www.4shared.com/...chassis_ls22myn.html
Monitor inner view:
https://www.youtube.com/watch?v=OzkXw6molww
clkout signal from main board connector, to lcd panel (20nsec hor timebase)
https://www.youtube.com/watch?v=yXStE0CfRyM
Jun 26, 2014, 5:42 PM
Post #8 of 15 (5929 views)
Did you perform self test and check for the fuse?Unimpressed
danielsoy
Jun 26, 2014, 8:33 PM
Post #9 of 15 (5926 views)
Yes, i did it ,but no luck....
BTW, there some meaningfull oscillograms on the LCD panel board,
so i know that it has vcc and I can see some signals that look like rectangular clocks.
But can´t tell for sure, who is the culprit.
Jun 26, 2014, 9:28 PM
Post #10 of 15 (5921 views)
Did you check for a fuse on the TFT attached PCB?
danielsoy
Jun 26, 2014, 10:38 PM
Post #11 of 15 (5919 views)
Yes, I found one fuse marked as: FU1, and it is not open.
Jun 26, 2014, 11:30 PM
Post #12 of 15 (5916 views)
Then, unless you can find a schematic for the panel assembly and repair the board, I'm going to agree that panel is bad. Subbing is only way to prove.
danielsoy
Jun 27, 2014, 2:13 AM
Post #13 of 15 (5912 views)
That´s right.
If I find info about the panel, will post back.
Thanks a lot for your help JTSTongue
Jun 27, 2014, 2:58 AM
Post #14 of 15 (5910 views)
What is panel nomenclature?Cool
danielsoy
Jun 27, 2014, 1:43 PM
Post #15 of 15 (5905 views)
Chunghwa 215FA01S.
Found this pdf.
http://www.4shared.com/...duG/lcd_dispaly.html
