LCD TV SHARP
Tech team
Oct 8, 2010, 6:01 AM
Post #1 of 5 (2182 views)
LCD TV SHARP Can't Post
I have a LC32D41U shutts off, right after turning on.
Oct 8, 2010, 6:26 AM
Post #2 of 5 (2181 views)
Re: [Tech team] LCD TV SHARP [In reply to] Can't Post
Another "change of tactics?"Wink
Maybe this will help?
Technical Bulletin
Number: LCDTV-211 Date: January 2008
Model(s): LC32D41U / LC32HT2U / LC32M41U / LC40C32U
LCD Television
Subject: Inverter unit shutdown.
Symptom: The screws securing the inverter unit loosen and the ground becomes intermittent
causing no or intermittent backlight.
Solution: Replace the six screws that mount the inverter. Do not reuse the removed screws.
New parts #LX-BZ2315TPZZ
JohnRocks
Oct 11, 2010, 6:21 AM
Post #3 of 5 (2169 views)
Hello jts,
Can you pls explain how this will help?
Rackmount LCD Monitor
USB KVM
Oct 11, 2010, 8:19 AM
Post #4 of 5 (2167 views)
Re: [JohnRocks] LCD TV SHARP [In reply to] Can't Post
It will eliminate one possibility.Smile
darstr
Oct 12, 2010, 3:34 PM
Post #5 of 5 (2155 views)
Re: [jts1957] LCD TV SHARP [In reply to] Can't Post
Technical Bulletin
LCD Television
New parts #LX-BZ2315TPZZ CrazyThis is one option. You can also move down the inverter board and make sure each black square is pushed down firmly. Very easy for these to pop loose and give you a shut down. If this does fix it, you will still need to force the backlights on and do a factory reset, or you will keep shutting down. Good luck to you.
