BPDtrustee
Oct 24, 2011, 3:58 PM
(1780 views)
Poloriod FLM-373b(again)
Hello, have a poloroid FLM-373b, with the common powerup issue, red to solid blue-then no response. Did the cap repair over a year ago with an upgrade to 35v caps. Set worked for a year and quit again. Tried replacing the same caps again to no avail. Ohm tested remaining caps on the board, and each seem to hold voltage, and each cap type has similar values. Transistors test good as well, no evidence of open or shorted diodes. Voltage outputs with set running are at the printed specs on all pins. houston please advise? possiblity of another component causing the same issue?
