Nov 24, 2014, 10:07 PM
(2060 views)
Re: [aeverett] Sharp 46 inch no power
POWER indicator (Red): The TV is in Standby. Press POWER on the TV or the Remote to turn the TV ON. IF the above doesn't restore normal operation ... Is BD901 (+320V) output? (Set the main power SW to OFF.) * When power on/off switch is on ... About +400V? Is a voltage of +5V applied to pin (11,12) of connector (CN903)? (Set the main power SW to OFF.) Are +12V output as for the power on/off switch when it is on? ------------------------- Location: Far, Far Away
(This post was edited by jts1957 on Nov 24, 2014, 11:18 PM)
