Nov 17, 2015, 7:37 AM
Post #4 of 5
(2416 views)
Re: [pzazzera] Sony Bravia KDL-46XBR4 - Blank Screen
I gave the info necessary to determine whether your "Blank screen" was a 'No Video' or a 'No Backlight' condition (I was anticipating needing Flowchart 'F' or 'G.') (You made No mention in your initial post that the set was shutting down, nor the red Timer LED was flashing.) Flowchart C would cover the red Timer LED Flashing. I do NOT have your TV in front of me. You have to specify how you are arriving at a conclusion. "If the back cover is off, there are numerous holes in the rear of the panel chassis where the backlights can be easily seen. In almost all cases where the backlights do not light, the unit will shut down and indicate a diagnostics failure that will appear as a 6X (inverter) or 13X (balancer). This scenario is covered in Chapter 5 of this manual." SO .... Flowchart A: 'Is red Timer LED Flashing?' (HOW MANY Flashes? 6 or 13?) ------------------------- Location: Far, Far Away
(This post was edited by jts1957 on Nov 17, 2015, 7:39 AM)
