jack_in_Dallas
Apr 1, 2023, 4:11 AM
(3100 views)
Vizio e600i-B3 problem - Need Help!
My Vizio e600i-B3 60" LED-backlight LCD TV recently dimmed significantly. After tearing it down, I discovered 8 bad LED strips. Ordered replacements via eBay, installed them, worked GREAT! HOWEVER, as I was re-assembling the TV, the front LCD panel buckled as I held it tightly at the top corners - bent like a "U" - but didn't hit anything. I didn't hear any damage happening.... I then panicked, and forgot how I had placed the various panels that sit atop the LED array. I tried how I THOUGHT it went, but there was very little light shining thru to the front screen. Then there was some garbage, which I'm 99% certain is a direct result of the screen buckling while moving it. But, just for kicks, can anyone help me with the sequence of installing the FOUR white panels? There is one THICK panel, and three much thinner panels. I can post pictures later tonight or tomorrow if that helps. Thanks in advance! Jack in Dallas
