disable tv reception
mikeincog
Mar 7, 2010, 4:14 PM
Post #1 of 11 (3225 views)
disable tv reception Can't Post
I am getting a Sanyo LCD HDTV model# DP26649 for playing Wii video games. I would like to modify the tv so that it will not receive broadcast tv or be able to watch dvds. I would prefer a technique that would be reversible, but will permanently disable it if necessary.
I understand that tvs have parental control functions. That is not what I am looking for. I want to physically disable the ability to watch tv. Thanks!
Mar 7, 2010, 4:54 PM
Post #2 of 11 (3223 views)
Re: [mikeincog] disable tv reception [In reply to] Can't Post
when you switch on the tv the microprocessor interrogates the internal workings of the tv to ensure all is working before it allows the tv to start up. if you go removing bits or cutting supply voltages here and there the chances are the set will not power up. have you thought about not plugging the antenna in or not buying a DVD? it's much simpler and your friends won't think you are a basket case.
mikeincog
Mar 7, 2010, 5:14 PM
Post #3 of 11 (3222 views)
Re: [techchris] disable tv reception [In reply to] Can't Post
Thank you for that info. Is there something I can do perhaps to the jack that receives the antenna? I do need the ability to physically disable this (and my friends already think I am unusual).
Mar 7, 2010, 8:47 PM
Post #4 of 11 (3220 views)
Remove the Tuner(s) and whichever input jacks(s) you don't want. If you're real good with desoldering, you may "float" the pins (or you may have to completely remove tuner & jacks and store them in a baggie).
As techchris said, doing this may result in set reporting an "error" (or not allowing set to run).
Why not install TV in a cabinet with doors (or build a "box") and lock up the set?
(This post was edited by jts1957 on Mar 7, 2010, 8:51 PM)
mikeincog
Mar 8, 2010, 5:54 AM
Post #5 of 11 (3214 views)
Re: [jts1957] disable tv reception [In reply to] Can't Post
I can't lock up the set in a cabinet because I have to allow unrestricted access to the wii for the kids that are trustworthy. There are other relatives that come over at times that can not be trusted.
But I don't want to risk making the device not work at all. What do you think would happen if I put super glue in the jack, then plugged in the antenna, then cut off the plug? (So that the input jack was in effect plugged-up)
Mar 8, 2010, 5:11 PM
Post #6 of 11 (3209 views)
look inside to see if the antenna socket is part of the tuner or separate. if it is a standalone socket,just remove it otherwise just cut off the centre pin of the socket.
Mar 8, 2010, 7:37 PM
Post #7 of 11 (3207 views)
mikeincog;....
I can tell you with 100% certainty that that is a dumb idea....
The 2 quotes above are in conflict with eachother....
IF you superglue anything , do you really expect it to be reversible ???
IF you superglue the jack or connector with wires/cables hooked up to it , you can kiss that connector/jack goodbye....PERIOD !!!!
IF the connector is on the tuner , well , good luck trying to reverse that....
WHY would you want to permantly disable the tuner ???
Is the TV STRICTLY for the kids use ???
IF that's the case then what you are trying to accomplish makes sense..,..
But next time I'd reccommend you buy a monitor....
GOOD LUCK & have fun....Sly.....
Later...Ron.M....Cool....
dgdfgttttt
Mar 17, 2010, 3:27 AM
Post #8 of 11 (3186 views)
Re: [Ron.M] disable tv reception [In reply to] Can't Post
http://www.dvdmsn.com/...d-box-SET-p-592.html
http://www.dvdmsn.com/...5-box-set-p-527.html
http://www.dvdmsn.com/...d-box-set-p-594.html
(This post was edited by dgdfgttttt on Mar 17, 2010, 3:29 AM)
freethink
Apr 13, 2010, 5:56 AM
Post #9 of 11 (3155 views)
I don't think you can do it reversibly. Everyone I know who's done something like this has had to solder at some point
http://buylogitechharmonyoneadvanceduniversalremote.com/
JohnRocks
May 12, 2010, 4:45 AM
Post #10 of 11 (3106 views)
Actually, I am not deep regarding this problem; it is the general thing that you will have to maintain the antenna. If I get any information related to this post, I would with you. Thanks for comment.
Rackmount LCD Monitor
USB KVM
cobby2510
May 24, 2010, 10:54 AM
Post #11 of 11 (3080 views)
i'm thinking why you want to do it. so you indeed an unusual person!
and if i was you, maybe i will get a signal jammer. i can control this kind of jammer to let it work or not via starting or closeing it. so that it is easy to reach the requires what you want...
When can I buy this kind of waterproof TV for my bathroom?
