SONY KE-42TS2E
t1412
Jan 31, 2010, 10:39 AM
Post #1 of 8 (7046 views)
SONY KE-42TS2E Can't Post
hello just pick this tv up for a m8 to repair it's a sony plasma model number KE-42TS2E. at switch you can hear the fan boot up and then aloud buzz and spark flash of the screen then shuts down with the led blinking i've opened it up and found 4 large cpacitors 2200mf 100v bulged i've change them tv still the same any info would be great or a schematic would be better thanks for your time
regards
shaun
Repair man
Feb 1, 2010, 5:44 AM
Post #2 of 8 (7039 views)
Re: [t1412] SONY KE-42TS2E [In reply to] Can't Post
Hi Shaun -- Check diodes near the caps you changed, if any are bad it will cause caps to bulge.
Here are a few more things I found in my notes from past repair jobs of that set ...
Check the connections on IC 1019 located on the B-board #875966950,
Replace the B-board #A1300914A, the board should be located above the tuner assembly
Hope this helps, Dan
Learn Plasma TV Repair
_________________
Learn LCD TV Repair
t1412
Feb 1, 2010, 5:14 PM
Post #3 of 8 (7035 views)
Re: [Repair man] SONY KE-42TS2E [In reply to] Can't Post
ok dan thanks mate
shaun
t1412
Feb 2, 2010, 8:04 PM
Post #4 of 8 (7026 views)
does any 1 know where i can get ribbon cable from for a sony plasma the code for cable is E66085 AWM 20706 105C 60V VW-1 BANDO'S thanks for you time
regards
shaun
denonjapan
Feb 6, 2010, 7:28 AM
Post #5 of 8 (7016 views)
Partstore.com carries major electronic parts, open 24 hours. if you can disengage the tuner section, then power up. if stays on! then tuner is the problem. if it does thesame? better off get rid of it.
denonjapan
made in japan
t1412
Feb 6, 2010, 11:40 AM
Post #6 of 8 (7014 views)
Re: [denonjapan] SONY KE-42TS2E [In reply to] Can't Post
ok i'll give it ago thanks
regards
shaun
popemike
Feb 17, 2010, 3:49 PM
Post #7 of 8 (6991 views)
I have a similar problem see:
I put in a reccycled B-Board and same problem as before. The power led lights up, the fan comes on, the screen flashes very quickly a white light, the sleep timer light flashes once, relay RY101 clicks on the power switching board, then the power goes off - shuts everything off - remains off for 30 seconds and same happens again. This will continue 2-4 times then it shuts off.
Is this still a B Board problem - did they send me a bad BBoard?
I am to get a second new B-Board today and will let you know what I find out.
Do you have a pictorial layout of the Power switching board Sony APS -192 part no:1-468-720-11? Can you send it to me - I can not find it on the net.
Thanks
(This post was edited by popemike on Feb 17, 2010, 4:35 PM)
t1412
Feb 18, 2010, 7:12 PM
Post #8 of 8 (6980 views)
Re: [popemike] SONY KE-42TS2E [In reply to] Can't Post
i striped the tuner down reconnected the cables and powered up the tv and it came on ok got the menu up i did't check for picture as it's at the back of my living room aerial to far away. i put the metal cover back on powered it back up again nothing dead i'm sure the plastic ribbon cable my be my problem. some of the metal ends some are missing have you check the 4 large capacitors to see if there are swelled on your set there are 2200mf 100v
shaun
