Jul 15, 2010, 2:33 PM
Post #2 of 3
(3300 views)
Re: [roledzki] Sanyo DP42746 Question
This is all the service manual says about a flashing LED: LED Flashing When IC801 detects the Power Failure 3 times the LED will flash to indicate a power failure has occurred. NOTE: The LED does not flash for Temperature Failures. NOTE: If power failure is detected 3 times in 15 minutes, the set will enter the standby mode and cannot be switched On. To reset the operating programs of the CPU it is necessary to disconnect the AC cord for a short time. ------------------------- Location: Far, Far Away
