Toshiba pixel noise
mgmlot93
Oct 17, 2007, 2:44 PM
Post #1 of 8 (1842 views)
Toshiba pixel noise Can't Post
I have a Toshiba 42" plasma and lately it has started acting up with what I believe you call pixel noise. One second the picture is fine and the next second you see bursts of color in the pixels throughout the screen - of course mostly noticeable on a black background object. Is this repairable like the Zenith problem discussed below? Thanks in advance for any help.
denonjapan
Oct 17, 2007, 11:26 PM
Post #2 of 8 (1830 views)
Re: [mgmlot93] Toshiba pixel noise [In reply to] Can't Post
You have an overheating scaling chip. I'm not giving you hope to replace it cause this can't be done by hands or manual procedures. You may contact toshiba under your existing warranty if new than I suggest you to replace it. `
denonjapan
made in japan
MOtvGuy
Oct 20, 2007, 8:14 AM
Post #3 of 8 (1820 views)
I've had a couple of newer Toshiba's come in with "sparkles". Occasionally you can adjust it out but the best fix is to replace the X & Y sustain boards along with the Logic board.
That, by the way, is the same fix as for the LG's. Those parts actually come as a kit.
mgmlot93
Oct 22, 2007, 4:07 PM
Post #4 of 8 (1812 views)
Re: [MOtvGuy] Toshiba pixel noise [In reply to] Can't Post
Is that a repair that can be done at my house or will I have to take the unit in? Approx cost?
Thanks for all the help.
MOtvGuy
Oct 26, 2007, 11:38 PM
Post #5 of 8 (1793 views)
A tech should be able to repair that in the home. As for price.
Bend over baby. Wink
mgmlot93
Oct 27, 2007, 5:35 PM
Post #6 of 8 (1789 views)
Is it worth fixing? Are we talking about a few hundred dollars or much more? Thanks
denonjapan
Oct 28, 2007, 7:10 AM
Post #7 of 8 (1784 views)
to bend over and few hundred dollars don't even come close. But you can gamble a win win or loose situation. no hard feelings aside.
denonjapan
made in japan
MOtvGuy
Oct 30, 2007, 11:36 AM
Post #8 of 8 (1770 views)
The cost of the 3 boards will cost you several hundred. Since I have no idea of the range of what service companies charge in your area I really can't even come close to giving you a ballpark figure. I'm guestimating here:
X & Y sustain boards and logic board - $300-500
Cost of service call and in-home labor.
