jpt54
Aug 31, 2005, 4:33 PM
Post #3 of 10
(4770 views)
It was £1,750, not $1,750. I have no idea for a different market price. 1/ New technology has expanded the life of new plasma from 10,000 hrs to 30,000 hrs. The more you use, the sooner you have to buy a new one. 2/ Do you ask about "screen refresh rate"? The larger number, the faster rate. If you use 60Hz and you detect the flicker on your screen, you can select 100Hz to reduce it. 3/ Plasma has two versions. Not all plasma is HDTV. The low resolution plasma is EDTV. The higher resolution one is HDTV, and of course it's more expensive.
