denonjapan
Dec 1, 2004, 1:18 AM
Post #2 of 8
(3559 views)
if the Plasma has it's own built in tuner, all you need is coaxial cable from your antenna (roof antena). Yes! all you got is ED channels. I would say lower quality than an HDTV tuner can provide. Chances are, when you use a separate HDTV Capable receiver, you will have a progressive picture: lower resolutions channel will be process by the HDTV Receiver and then FIT an appropriate resolutions still look state of the art into your flat screen. If you are new to this, Im pretty sure it's not quite clear to your unless you have the unit and work it through experimentation. Don't worry! you can work your way out.
