Blue too bright
Wiz
Apr 23, 2006, 1:25 AM
Post #1 of 2 (1576 views)
Blue too bright Can't Post
Hi I have a crt projector from the 1980's, its made by esprit and model 300.
The problem is that the blue crt is much brighter than the other 2. As well as the blue being too bright, there doesnt appear to be any picture coming from this tube.
I have tried adjusting the brightness of each of the tubes, which doesnt seem to have made much difference.
I hope that you will be able to give me some help as I guess that this projector works on the same principals as a projection tv.
Oliver
mikemaiertv
May 12, 2006, 10:04 PM
Post #2 of 2 (1540 views)
Re: [Wiz] Blue too bright [In reply to] Can't Post
Lets attack this from a few angles, If the set did this real suddenly it may simple have a component on the crt driver board fail, if slow maybe the tube craped out, Does the set have squiggle or zigzag lines in the blue? This called retrace, could mean the tubes bad, does turning down the screens improve this at all, can you swap the red crt board with the green and see if the problem moves to the green, if so then it’s a component fail if not the crt is bad. But with no video I suspect a bad CRT. Now here’s the problem, many manufacture only stock replacement parts for 8 years, but maybe this CRT crosses to another one that is still in production somewhere. Then the final question at 25 years old what else is going to fail, Capacitors dry out with age as well as usage.
