Dec 30, 2010, 1:59 AM
Post #3 of 4
(2285 views)
Re: [InuGoku] Cant locate problem
InuGoku;..... Since you are an admitted novice & the TV wants to play games with you (& you appear to be losing), I reccommend you get the whole shooting match... This kit has EVERYTHING you need.... A bit pricey for us pro's ($68.95 +s&h) , but if you (the novice) had gotten it in the first place , you'd be watching football on a 51" TV instead of looking at a 51" TV cabinet... .... Here's the link;=>... http://www.tvrepairkits.com/xcart/home.php?cat=3539 Scroll down a bit to get the info.... Here's what you get;=>... - OEM Sanyo Convergence Chips. Each kit includes the correct replacement convergence chips verified against the service manuals. Two chips per kit unless your model uses three - in that case we ship three. These are genuine OEM Sanyo chips. Sanyo was the primary supplier of convergence chips used in TV sets made by Philips, Sony, Hitachi, Panasonic, Toshiba, Mitsubishi, and many others). We do not use lower quality generic convergence chips in our kits like other sites. .
- Convergence Resistors - These are specifically designed and rated for convergence circuits. Do not use anything but convergence rated resistors when doing these repairs.
- Thermal Paste
- Photo Instruction Manual - Complete Instructions on how to repair your TV. This is a step by step photo instruction guide that will walk you through each step of the repair. All of our repair guides are non technical and easy to follow. You do not need to have any prior electronic repair experience to use this kit.(Download Version - allows you to view/zoom/print from your computer)
- Soldering Instruction Manual - Complete instructions on how learn to solder like a pro in less that 30 minutes.
- Email/Phone/Live Chat Support
ALL the above is for YOUR model TV.... GOOD LUCK.... ..... Later..Ron.M..... ... Veteran & Retired TV technician
