Hello all I did the coolant change out, i also opped in to take each CRT out of the magnavox (one by one), i pulled the crt board off the back of the CRT and pull off both gnd wires, the only thing left to un plug was the H.T flycable that i undid from the tripler/bridge and the magna field coil
then i could un do all 4 screws on each CRT, and undone each crt one at a time, red, green blue...
i took the housing apart and took out the old coolant, red and green was ok but i replaced it anyways.. the blue however was very dirty and had a lot of crud build up on the face of the CRT, i cleaned it all out and flushed it with alcohol dried it off and refiled with new coolant,whased the gaskit and remounted the gaskets and housing doing up the 4 bolts that secure the housing to the CRT, and then remounded the backplate to the entire CRT and securing them with the 4 spring bolts.
i did this to all 3 CRT's, one bay one and reinstalled them as i went.
anyhow, the picture is wonderful, but some how i
screwed up
what i get when viewing the TV is flare outs, like a ghost image along side the real image, and towads the bottom it also flares out lower left and right and bows the refelction up frm the lower center, i did go into the convergence config set up, there is no flare outs in that mode, when i retuen to normal tv screen the flare is still there
the picture is much more brighter than before and i even have white for the first time insted of a yallow pink color...
dose anyone know how i can cerrect the picture iamgat and phaze the flare back in to faze to the real image?
i am thinking that i mush have bumped the yoke or the yoke tabs, would this cauls the flare out image problems that i am seeing on the screen?
any help advice i will be watching this post like a bird for any advice...
thank you in advance for any help and info
i will now try and upload some images that i took with my digital cammra
7 3
Mark
