Larrybia
Jun 13, 2005, 2:25 PM
(1823 views)
I have a 1992 Mitsubishi Projection TV with a very dim picture. Green is a little better than the other two colors. I have turned up the drives on the CRT using the control at the base of the CRTs and can get a little better picture but still dim. I guess the CRTs are bad? Is there any reason to suspect low HV or some other problem with the brightness circuits? I say this because all colors are dim and I am hoping that there may be some other fix than replacing the CRTs. Has anyone considered increasing the CRT filament voltage like they use to do in the olden days? I measured the filament voltage and it was 7 VAC. I am considering putting in a variac in series with the filaments and increasing the voltage to see if I can increase the CRT brightness’s. I may also try a separate DC supply. The filaments are not very bright as they are now. Any idea how much the filaments can take? Worst case is that I burn out a CRT and I just junk the whole set. With no other suggestions I will do the experiment. Let you know the results. Larry
