Feb 15, 2010, 12:30 AM
Post #4 of 6
(2743 views)
Re: [jts1957 & youknow21 ] Hitachi 50FX30B
jts1957;... I took the back off off it and there are 6 leds 5 of them are green the other is >>RED<< Thanks This bothers me a bit..... According to my service manual , there's D950 thru D954 which are "leds" & indicate various low voltage power supplys are working when green... IF one of those is "red" it could be that circuit that is causing his problem.... Before anyone ( NOT you jts) starts jumping up & down , YES , I did see that he has a menu display , so he has High Voltage & D975 the protect led IS green.... youknow21:.... Concerning that "6th" led (the "red" one) , can you give us a circuit reference # , like D950 thru D954 or whatever it is ???? Thanks , that would clear things up.... And i have nothing connected to the tv it is on channel 3 and it used to show a white screen but now it shows nothing the first time it done this we just left it on for about a month and it come on and stayed on so we never turned it off we had a power outage here and ever since then the tv has been on for about 2 months and never has come on NOT a good idea to leave on 24/7 for months on end.... I suspect that it is unattended at times... You are asking for the possibility of serious problems includeing fire damage to the TV &/or your home....Your call... Later...Ron.M.... .... Veteran & Retired TV technician
(This post was edited by Ron.M on Feb 15, 2010, 12:47 AM)
