JVC 48" Problem
MrSlithers
Nov 15, 2010, 8:02 AM
Post #1 of 17 (2715 views)
JVC 48" Problem Can't Post
I've searched my livin booty off and can't seem to find an answer. I just got this TV for free from a buddy as long as I got it out of his garage. It's a JVC 48" 48wp74. The red and green work great but the blue has a streak that runs through the screen. I have no idea what it might be. I emailed a few tv repair shops to no avail.... I went to the convergance thing and the blue was pretty out of whack. I would marry the person that figures this out as im tired of watching my 22" LCD from 20 feet hahaha.
Nov 15, 2010, 8:00 PM
Post #2 of 17 (2712 views)
Re: [MrSlithers] JVC 48" Problem [In reply to] Can't Post
MrSlithers;....
Neither do we .....
IF you could post a few pix of the problem , I'm sure it would help us out in figuring out what your problem is....
May or may not be a convergence problem....
I would marry the person that figures this out ...
I for one will pass.....
Just a "Thank you" is enough....
Later...Ron.M....Cool....
MrSlithers
Nov 16, 2010, 12:05 AM
Post #3 of 17 (2704 views)
Re: [Ron.M] JVC 48" Problem [In reply to] Can't Post
Nov 16, 2010, 12:50 AM
Post #4 of 17 (2701 views)
MrSlithers;....
One of us needs glasses (eyeglasses & NOT beer glasses) & it ain't me.....Wink....
Care to try that again....
This time , check for clarity (focus) on your camera OR,....
After you paste them in your post , click on the "Preview Post" button located near the center bottom of the area you are typeing in....
It will change to the post you will see in your thread...
If the pix is bad , scroll down & un-paste it & make any changes needed (in your camera) to get a decent pix....
OR re-take the pix....
I can barely make out 2 possible problems , but , need clearer pix to confirm....
Later....Ron.M....Cool....
MrSlithers
Nov 16, 2010, 2:15 AM
Post #5 of 17 (2697 views)
The camera won't focus on the TV. These are about the best I can do... It's just a blue streak as seen in the pictures.
http://img.photobucket.com/...Pavicon/DSC00639.jpg
Nov 16, 2010, 4:55 AM
Post #6 of 17 (2696 views)
I'll bet one choice is a 1999 movie starring Martin Lawrence and Luke Wilson. Smile
MrSlithers
Nov 16, 2010, 5:53 AM
Post #7 of 17 (2694 views)
Re: [jts1957] JVC 48" Problem [In reply to] Can't Post
It's the Perfect Storm haha
Nov 16, 2010, 7:39 PM
Post #8 of 17 (2687 views)
MrSlithers;.....
Based on that blurry mess I'm looking at ,
#1=..I'd say you have a bad convergence IC (Replace BOTH !!!)....
#2=..Blue focus is out &/OR...Bonus fault=
#3=..contaminated coolant....
To determine #3 , you will have to remove the front screen & look directly into the blue CRT lens...
If you need more info , post....
I'd look for a better camera , get rid of that crappy one you have now...
Good Luck....Sly.....
keyword
Nov 18, 2010, 3:45 AM
Post #9 of 17 (2681 views)
Thanks for sharing the useful information.
Friday Night Lights dvd
Friday Night Lights 4
Collect cheap dvd at dvdbestonline
darstr
Nov 19, 2010, 10:13 PM
Post #10 of 17 (2668 views)
Crazy Ron I agree with issue# 1. I have seen this many times in JVC sets. Normally it is the green though. But all in all. Convergence IC's is the way to go.
MrSlithers
Nov 20, 2010, 11:18 PM
Post #11 of 17 (2661 views)
Re: [darstr] JVC 48" Problem [In reply to] Can't Post
Where can I pick up or order new ones?
Nov 21, 2010, 8:54 PM
Post #12 of 17 (2653 views)
MrSlithers;......
The ICs you need are STK392-110....
You will need 2 of these....
I reccommend you use ONLY Sanyo replacements as the generics are guaranteed to give you problems...
Also , please don't get cute & replace them with ANY up-grades like STK392-150, again problems VERY possible...
One source;=>...
http://www.mcmelectronics.com/...K392-110-/STK392-110
$16.75 +s&h....
OR;=>....
IF you go the eBay route , this one seems legit....
http://cgi.ebay.com/...mp;ff4=263602_304642
Don't forget heat sink compound;=>....
http://www.mcmelectronics.com/...at%20sink%20compound
Scroll down to item # 20-4505...
$3.09 ea. & enough for your ICs...
You can order them when you order the ICs & save on s&h...(Same company)...
I suggest you get the ICs & heat sink compound from MCM.....
OR find your own suppliers...
Also check ALL 1 &/or 2 watt resistors near the ICs for value...
Some may be burnt or off value due to the IC(s) going bad...
Replace any that are....
OR you can go here & get the whole kit & kaboodle;=>...
http://www.tvrepairkits.com/xcart/home.php?cat=2536
You get this + ;=>
Kit Includes
  • OEM Sanyo Convergence Chips. Each kit includes the correct replacement convergence chips verified against the service manuals ( STK392-XXX, STK394-XXX etc ). Two chips per kit unless your model uses three - in that case we ship three. These are genuine OEM Sanyo chips. Sanyo was the primary supplier of convergence chips used in TV sets made by Philips, Sony, Hitachi, Panasonic, Toshiba, Mitsubishi, and many others). We do not use lower quality generic convergence chips in our kits like other sites.
  • Convergence Resistors - These are specifically designed and rated for convergence circuits. Do not use anything but convergence rated resistors when doing these repairs.
  • Thermal Paste
  • Photo Instruction Manual - Complete Instructions on how to repair your TV. This is a step by step photo instruction guide that will walk you through each step of the repair. All of our repair guides are non technical and easy to follow. You do not need to have any prior electronic repair experience to use this kit.(Download Version - allows you to view/zoom/print from your computer)
  • Soldering Instruction Manual - Complete instructions on how learn to solder like a pro in less that 30 minutes.
  • Email/Phone/Live Chat Support
For $64.95....
Your Call.....
GOOD LUCK.....Sly....
BTW;.....
Yer Welcome.....Smile....
Later....Ron.M.....Cool...
MrSlithers
Nov 23, 2010, 6:53 AM
Post #13 of 17 (2641 views)
Awesome. Thanks! Im gonna order the parts this week. I found on youtube on how to replace them. I've got 1 more problem though. On alot of the channels, the picture is larger than the screen. I hate it when i'm watching the hockey game and can't see the score or the scroll menu for Charter..... Is there a way to fix that?
Nov 23, 2010, 6:24 PM
Post #14 of 17 (2636 views)
MrSlithers;....
Which way are you going & where are you ordering the ICs from ????
On alot of the channels, the picture is larger than the screen....
Maybe....
How much electronic/TV repair background experience do you have ????
Need honest answer....
Later....Ron.M....Cool.....
Nov 23, 2010, 10:29 PM
Post #15 of 17 (2632 views)
"He's a logger."Wink
Nov 23, 2010, 10:47 PM
Post #16 of 17 (2627 views)
jts1957;....
He's a WHAT ????
Is he going to solder with a blowtorch & an axe ????
I don't think so .....
Later....Ron.M.....Cool......
Nov 23, 2010, 11:11 PM
Post #17 of 17 (2625 views)
http://www.youtube.com/watch?v=SNr1eZopzZ4
