Magnavox problem
Eeyore
Jun 14, 2009, 5:46 PM
Post #1 of 3 (1529 views)
Magnavox problem Can't Post
I aquired a Magnavox PTV910... 55P8288 serial #66925424. I got this free so am not too concerned if the thing is toast!!!
The problem is it will not stay turned on, I have it in the garage as I wanted to check it worked before getting it into the house. I turned it on and the on button is red, it took a bit of searching to figure out how to clear the parental security codes but got it done. Now, I can have the set turned on with no signal to it (no cable/attenna in garage) and it seems to stay turned on, however if I try to play my dvd player through it, it immediately turns off.
Any ideas what this could be ?
Is the thing worth repairing?
Thanks in advance
jasonbird
Jun 16, 2009, 2:40 AM
Post #2 of 3 (1519 views)
Re: [Eeyore] Magnavox problem [In reply to] Can't Post
Emmmmm,
I dont think so~
SmileSmile
Cheap Ed Hardy
Jun 16, 2009, 6:17 AM
Post #3 of 3 (1516 views)
Hook the TV to a Variac and run it at a lower AC voltage. If it runs at say 90VAC with or without "signal," most likely power supply/regulator defective.
