csp
Sep 23, 2005, 2:25 AM
(2387 views)
Re: [tcompton] Mitsubishi 65" Problems
Hi Trent, It looks as if your convergence ic's are failing. If that is all it is, it is a cheap and quick fix. Ic's will will run approx $8 each x2. Old ones will have to be de-solderd out and new one soldered in. The convergence ic's are mounted on very large heat sinks on the convergence bd located in the back of the set. I am not familiar with Mitsubishi, but you can't miss the heat sinks. Most convergence ic's are labeled stk-xxx-xxx. Hope this helps.
