Mitsubishi VS-45609
psalz
Jul 26, 2007, 9:34 PM
Post #1 of 14 (4586 views)
Mitsubishi VS-45609 Can't Post
Hello,
New to forum. Hoping for some direction. Have tv as listed. Picture is snowy as if no reception on all channels. VCR does not input to TV. Front input jacks and S-video work. Checked cabling with known good cables.Checked cable jack as well. All OK. TV had been working flawlessly previous.
Any help will be greatly appreciated.
Thank you in advance
Pat
mikemaiertv
Jul 31, 2007, 7:25 PM
Post #2 of 14 (4572 views)
Re: [psalz] Mitsubishi VS-45609 [In reply to] Can't Post
Normaly we dont give the secret codes out over the internet, people tend to change crap around in the service menus and screw sets up real bad. But it sound like your set needs a kick in the brain so here goes,,, with the original Mits remote hit the "menu" button followed fast with 0-1-7-0 this will bring up a screen where the first option already highlighted is "Initsulize" if highlighted hit enter on the remote. this may or may not fix the set
psalz
Aug 2, 2007, 12:54 PM
Post #3 of 14 (4549 views)
Re: [mikemaiertv] Mitsubishi VS-45609 [In reply to] Can't Post
Thanks Mike.
Gave it a whirl last evening. No changes. Acts like cable is disconnected. I did verify cable and cable jack with known good cable an TV. If there's anything else I could try, I'd appreciate it. My email is psalsano@msn.com.
Thanks again,
Pat
onetech
Aug 2, 2007, 5:49 PM
Post #4 of 14 (4539 views)
Pat,
It sounds like you've lost the 32v to the tuners. This would be a power supply problem.
psalz
Aug 3, 2007, 10:02 PM
Post #5 of 14 (4526 views)
Re: [onetech] Mitsubishi VS-45609 [In reply to] Can't Post
Is there a test point where this can be measured?
Thanks
onetech
Aug 6, 2007, 3:38 PM
Post #6 of 14 (4510 views)
You can check pin #1 of connector "KB" which is the 32v output from the power supply or check at pin BTL on the tuners themselves, this chassis has two tuners.
psalz
Aug 6, 2007, 6:44 PM
Post #7 of 14 (4503 views)
Thanks,
I will check this evening.
Thanks
Pat
psalz
Oct 9, 2007, 6:18 PM
Post #8 of 14 (4365 views)
OK. It's been a while since I last responded. Finally had some time to look further. I found visually blown diode D746 on signal board. Does anyone have spec for replacement component? How about replacement/refurbished boards? Last question, has anyone come across this before?
Thanks to all,
Pat
onetech
Oct 10, 2007, 3:16 PM
Post #9 of 14 (4360 views)
Pat,
D746 is a 5.6 volt .5 watt zener diode. Should be available at most electronics supply houses or try Radio Shack. Did you check the 32 volts at the tuners?
(This post was edited by onetech on Oct 10, 2007, 3:18 PM)
psalz
Oct 10, 2007, 3:28 PM
Post #10 of 14 (4354 views)
Onetech,
Thanks for the diode info. I have not checked yet. Can I check with signal board removed at KB connector? Or will that do possible further damage to power supply.
Thanks again,
Pat
onetech
Oct 10, 2007, 10:13 PM
Post #11 of 14 (4346 views)
I'm not sure if the power supply will startup with the signal board disconnected. Better have it connected as this would give you an accurate reading of the voltages.
psalz
Oct 16, 2007, 1:25 PM
Post #12 of 14 (4324 views)
One tech,
Having some trouble locating diode. Would you know the current rating?
Thanks,
psalz
onetech
Oct 16, 2007, 4:00 PM
Post #13 of 14 (4319 views)
psalz,
Zener diodes are rated by voltage and power.
The diode in question is rated @ 5.6 volts .5 watts ( this would be .09 amp.)
The generic number for the diode is 1N4734A
an NTE/ECG #136A
The Mitsubishi part number is 264P461050 (this is a replacement for the original 264P484040)
This is available from Digikey on the web for about $6.00 with shipping (the actual part is less than a dollar)
Also check the 32v to the tuners.
Hope this helps.
psalz
Oct 17, 2007, 12:11 AM
Post #14 of 14 (4313 views)
Onetech,
Big help. Was on digikey site earlier today. I'll be in touch.
Much thanks,
Pat
