tekmenlos
Apr 5, 2006, 11:51 PM
Post #5 of 9
(2092 views)
Re: [MMacys1] Mitsucishi Wt42413
Yikes, you got a big problem no! You just have bad STK's, they are what control your convergence, it is very important that you do not try to fix this issue, if it doesn't move. Stop trying, whenever you fix it you convergence will be very off. The STK's, as I said before are IC's that control your convergence. IC801 & IC802 located on your main board, in this case they are STK394-250 part # 267P173010. Now, all you need to do is change them out, you will need to do soldering. Lots, make sure you do not bridge any of the pins. If you would like to, I can send you the service manual for $5.00 for this TV that could help you out a lot. Let me know at tekmenlos@yahoo.com. ...Lates...
