PTK-169 PIP BYPASS
CALVINPROCTOR
Jul 16, 2003, 7:38 AM
Post #1 of 3 (1663 views)
PTK-169 PIP BYPASS Can't Post
Anyone know of a PIP bypass for PTK-169.... Have a set with no video, everything else okay.... Working blind -- no schematic -- I did find video going into PIP module but not coming out... If I can, I'd like to jumper it out of the circuit -- customer doesn't use it anyway.
Thanks for your help.
rocketman
Nov 16, 2006, 2:54 AM
Post #2 of 3 (1099 views)
Re: [CALVINPROCTOR] PTK-169 PIP BYPASS [In reply to] Can't Post
hi, sounds like you might have a scope. if so, why not probe around and see if you can pick up video coming out.
Larry E
Nov 17, 2006, 1:18 AM
Post #3 of 3 (1090 views)
calvin, just did one of those, wasn`t a video problem, turned out to be a vertical issue, which upon further troubleshooting turned out to be an open pin 2 to pin 3 on the flyback which supplies B+ to the vertical circuit. Easy way to check is turn on set and turn up G2 for green tube and then look directly into green lens and see what you`ve got, if it looks like a bowtie or a figure 8 laying on it`s side you have a bad flyback. There is no pip bypass for a 169 that I`m aware of.
