Panasonic CRT Rejuvenation
jclark52
May 11, 2009, 2:06 AM
Post #1 of 6 (1888 views)
Panasonic CRT Rejuvenation Can't Post
I have a Panasonic PJTV with TXFCRT09ESER CRT (red.) I need to connect to my Sencore rejuvenator, but I can't find in my list of tubes. Can anyone tell me what setup I need (G1, G2, Filament etc.) or if there is a cross over to an older PJTV CRT.
Thanks,
John Clark
May 12, 2009, 1:07 AM
Post #2 of 6 (1885 views)
Re: [jclark52] Panasonic CRT Rejuvenation [In reply to] Can't Post
There's this thing called "Google." Just searching for: TXFCRT09ESER, Fifth item down lists "CompatibleModels." Service literature for ANY of these would give schematic which should show which pin is which.Wink
Not related to (Chicagoland area) Ralph Clark?
jclark52
May 12, 2009, 3:48 AM
Post #3 of 6 (1880 views)
Re: [jts1957] Panasonic CRT Rejuvenation [In reply to] Can't Post
Thanks for the reply, but I was looking for the settings for my rejuvenator. I don't have this CRT number in my list of tubes so I don't know what settings to use.
I don't think I'm related to Ralph. Thanks again.
John Clark
May 12, 2009, 10:08 AM
Post #4 of 6 (1877 views)
John Clark
Unimpressed
You just want the settings and YOU don't want to be troubled by having to do ANY research yourself.
I suppose you don't want to spend the money with Sencore for the most current setup book either!
Call them or try the procedure for identifying pins in the operating guide.Frown
jclark52
May 12, 2009, 6:14 PM
Post #5 of 6 (1872 views)
(1) I don't need the pinouts.I need the switch settings for my rejuvenator.
(2) I searched the internet for hours before I posted here.
(3) I have already called Sencore and they are sending an updated book.
(4) Since this is a forum I thought maybe someone with knowledge of a rejuvenator might be able to give the switch settings so I could have them a little faster.
(5) Don't reply again because I don't need some arrogant person who doesn't know what I'm talking about.
(6) If you do reply, I won't read it.
(7) Please lookup what a TV rejuvenator is by using "GOOGLE."
Thanks for your kindness sir.
May 12, 2009, 9:38 PM
Post #6 of 6 (1866 views)
Owning one each of the Sencore CR7000 & CR70 -
My first post responds to your wanting to know both the pin out and other sets using the SAME tube.
My second post points out that the operation manual for the Sencores have a procedure to obtain pins and approximate switch settings.
