Panasonic PT-51HX41E issues
likeadodachacha
Jun 18, 2011, 11:06 PM
Post #26 of 30 (3072 views)
Re: [Ron.M] Panasonic PT-51HX41E issues [In reply to] Can't Post
Read your responses to others questions and you will see your arrogance, you’re here to help and all you want to do is put people down and flex your puny muscles. You responded exactly as I expected. Do yourself and others a favor and retire from the forum because you’re the joke.
Jun 19, 2011, 12:39 AM
Post #27 of 30 (3064 views)
Re: [likeadodachacha] Panasonic PT-51HX41E issues [In reply to] Can't Post
likeadodachacha;.....
I'm NOT Judas...
So when you spit in my face , do NOT expect me to turn the other cheek...
I will NOT kiss yours OR anyone else's @$$...
I'm here to help people including jerks like you & do a FINE job of it...
IF you become disenfranchised with my efforts , fine , how about giving a REASON BEFORE you start calling someone foul names...
NOWHERE did I see a reason given...
YOU STARTED this here;=>....
http://www.tv-forums.com/...i?post=102836#102836
There you have it Ron M. the TV is fixed and done without your complete assistance. There are plenty of other people out there that can help you fix something without having to deal with an arrogant a@$ hole like you. If anyone out there would like help with the same repair I hope this helps. All I can tell you is continue to search online and you will find the answer. Good luck. Bye Ron.
And then I answered you....
It takes a lot of balls to say that I'm the arrogant one when YOU called me an "a@$ hole" FIRST !!!!
Balls that I feel someone else has a good grip on...
I responded with the TRUTH , more than I can say about your post...
The truth hurts , doesn't it...
The truth is YOU STILL have a problem with the TV & aren't man enough to admit it...
That's YOUR problem & NOT mine to worry about....
Better a flimsy offense than an explanation of the truth...
Go have a crappy Father's Day & leave me/us alone....
....Ron.M....Cool.....
Jun 19, 2011, 6:12 PM
Post #28 of 30 (3051 views)
One LAST Parting shot !!! [In reply to] Can't Post
Webster says;=>....
ar·ro·gance [ar-uh-guhns] –noun offensive display of superiority or self-importance; overbearing pride.
Now let's look at your behavior....
Right up front you said;=>...
I have no experience in electronics.
Then I said in a later post;=>...
That may be a problem....However , I'll try to help you as best as I can...
I advised you in post #9;=>...
WARNING !!!!
While I was preparing this post I noticed you jumped the gun....
I do not tolerate that well especially since you did the WRONG thing...
Put the back cover BACK ON !!!!
We are going to do things from the front...
PLEASE follow my suggestions & instructions TO the letter OR you can mess
up the TV & ME !!!!
IF you do not understand my instructions STOP , POST & I WILL reply ASAP...
Be patient & we'll git er dun rite !!!...Wink....
Remember , HASTE MAKES WASTE !!!!
Then you went & did this;=>...
>> Well even though I know how you love it Ron I went and jumpped ahead << and used the electrical focus controls as listed on page 16 of the manual. That did the trick and I was able to adjust the sceen until the blue dissapeared. It looks like I just have to use the menu to adjust the final picture quality and it should be good. I really appreciate the advise and your time, though you really need to chill out alittle bit. Thanks again.
Also YOU said "Thanks"...(You were welcome..)....
Then I said this;=>....
I took your advice & am enjoying a DELICIOUS Strawberry Margarita...Angelic...
Then YOU went ahead & did this;=>...
(Edited quote) replace the STK392-150 convergence chips that were already installed in the tv. I did that and also discovered resistor R7056 which is a 2.2 ohm @ 2 watt metal film resistor burnt out. ... I'm into it for about $70.00. I'm not really sure I had to replace the convergence chips because the same problem I had before still existed.
And I laughed my @$$ off...
Because YOU took over the reins & ran the show from that point on while I LMAO !!!!
A SURE sign of arrogance on YOUR part....NOT MINE !!!!
I am an observer , remember ???
This pix below shows a problem STILL !!!!
To review....
ar·ro·gance [ar-uh-guhns]–noun ,offensive display of superiority or self-importance; overbearing pride.
If it looks like a Duck , walks like a Duck & Quacks like a Duck , it's a GD DUCK !!!!
So WHO is the arrogant one ???
Bye.....Ron.M....Cool....
Jun 20, 2011, 10:32 AM
Post #29 of 30 (3040 views)
Re: [Ron.M] One LAST Parting shot !!! [In reply to] Can't Post
Beat that horse Ron, beat it good!Smile
Jun 20, 2011, 4:33 PM
Post #30 of 30 (3034 views)
Re: [jts1957] One LAST Parting shot !!! [In reply to] Can't Post
jts1957;.....
The guy called ME arrogant...
I have NO other choice but to prove I wasn't ...
"Pot calling the kettle black" comes to mind , but , I'm not sure that applies in this case...
Had to REALLY prove I was NOT arrogant...
Speaking of horses.....
Have a GREAT Day & week.....Sly......
Later...Ron.M....Cool...
(This post was edited by Ron.M on Jun 20, 2011, 4:34 PM)
