boriquafl1
Jan 19, 2010, 2:09 PM
Post #1 of 4
(1696 views)
Philips 50P8341
Hi all, I have a philips 50p8341 PTV915, I just noticed that the tv shuts off by it self. It started recently I'm watching tv and next thing you know you cant use the remote for nothing at all, after that it shows a display saying that the tv will shut off in about XX seconds, after it shuts off nothing at all, I cant turn it on on the set or by the remote, I noticed that if I unplug it and plug it back in it will come on. I recently did a CRT coolant change and cleaned as much dust as I could, I ensured that all connections where tight and plugged in, after that it had a bad alignment, so after doing some reading I adjusted thru the service menu hitting 062597 code, I when ahead and did a manufacture reset, can I have thrown something out of wack thanks
