dillboy
Apr 20, 2006, 1:14 AM
Post #2 of 3
(1871 views)
there are a few ways to help a servicer diagnose a shutdown event such as yours. Without making you count blink sequences, we should be able to display on screen. this model contains an error buffer that stores the 7 most recent errors. these are very general errors but can stear one in the right direction.If your up for a challenge here go. turn unit on. with remote control press 0 6 2 5 9 6 MENU . it should display SDM in the right corner with other #'s and such. the info i would need is the seven #'s to the right of the ERR and i will gladly help if i can. after recording the numbers press the power button turn unit off. entering the service mode is a delicate procedure, so do not press anything in this mode until you press power.
