Phillips 55PP935217
Gus67
Dec 19, 2010, 6:38 PM
Post #1 of 12 (3151 views)
Phillips 55PP935217 Can't Post
I am looking for a service manual for a 55PP935217.If anyone has one or knows where to get one it would be a great help.
It appears to me it needs a convergence IC.The red convergence will not respond to adjustment.
BTW,
Ron,
keep your comments to yourself.I believe I am competent enough to draw the conclusion that this is most likely the problem,but before I make the decision to purchase the parts I want to see a block diagram and some schematics to come to my own decision.
Dec 19, 2010, 9:16 PM
Post #2 of 12 (3139 views)
Re: [Gus67] Phillips 55PP935217 [In reply to] Can't Post
Gus67;....
Ron,
For you, HaHaHaHAHa....NEVER.....
After that crap you pulled on me , lets see who is fool enough to help an @$$#ole...
Your compentency is questionable at best !!!!
And , NO , you don't want the manual for the "block diagram" etc...
You want the "Factory Menu" codes so you can go in there & "tinker"...
Rots of ruck with that...
Here's to you;....
May Santa literally take a "dump" in your stocking....
And the best of crappy new year to ya.....
Ron.M....Cool....
(This post was edited by Ron.M on Dec 19, 2010, 10:44 PM)
Gus67
Dec 19, 2010, 9:47 PM
Post #3 of 12 (3131 views)
Re: [Ron.M] Phillips 55PP935217 [In reply to] Can't Post
Ron,
Why would I want your help?
I clearly wrote that I did not want your comments.
I was asking if anyone...other than Ron, had a manual for this tv
That's all.
Lets be clear Ron,you are a looser who needs to knock people down in order to make yourself feel superior/smart.I don't want YOUR help.I am clearly looking for a manual so I can diagnose this problem.
This forum I believe is about TV repair.I have a TV with a problem and I am trying to repair it.So if I am correct in figuring you are only a participant and in fact do not run this website keep your comments to yourself.I can diagnose the problem without any input from you.
Dec 19, 2010, 10:43 PM
Post #4 of 12 (3129 views)
Here he goes AGAIN , folks !!! [In reply to] Can't Post
Gus67;......
What planet are you living on that you can EVEN think that I would EVEN THINK of helping you...
You are correct that I do not run this website or I'd run your @$$ outta here in a New York minute !!!!
You also do NOT have any authority to tell me where I can or can not post my comments.....
If you don't like it here , then go to another forum...
Don't come here & spoil our Christmas & New Year...
It was SOOOOoooooooo nice while you were gone....
Any chance you'll go AGAIN ???
Ron.M....Cool.....
(This post was edited by Ron.M on Dec 19, 2010, 10:45 PM)
Gus67
Dec 19, 2010, 11:04 PM
Post #5 of 12 (3124 views)
Re: [Ron.M] Here he goes AGAIN , folks !!! [In reply to] Can't Post
Hopefully Ron will now stop with the comments and I can sort this out.
Again,
I am looking for a service manual for a 55PP935217 Philips Projection TV.I have a convergence issue I need to figure out.
My problem is that the red is out of whack and does not allow me to fully adjust it in the convergence menu.I can adjust it left and right but not up and down.
From reading these posts I believe it could be the convergence IC but I would like to see a schematic and a block diagram of how it works before I jump to conclusions.I do not know how the circuit works so I do not want to assume anything.
I am an Electronics Tech but do not have much TV experience other than screwing around with this projection set a year ago.
Gus67
Dec 19, 2010, 11:07 PM
Post #6 of 12 (3123 views)
Re: [Gus67] Here he goes AGAIN , folks !!! [In reply to] Can't Post
Ron,
Really,stop with your nonsense.I like this site and do not want the harassment from you.
I posted that comment in my first post hoping to keep you from steering this post away from the topic.
Dec 19, 2010, 11:17 PM
Post #7 of 12 (3117 views)
Gus67;....
No , It's MY TURN !!!!
Gus67;....
Ron,
Here's to you;....
Gus67;......
Don't understand English very well do you ????
Ron.M....Cool....
(This post was edited by Ron.M on Dec 19, 2010, 11:17 PM)
Gus67
Dec 19, 2010, 11:18 PM
Post #8 of 12 (3113 views)
Is there a moderator who can help me out here?
Dec 19, 2010, 11:20 PM
Post #9 of 12 (3111 views)
Gus67;.....
You must think I have amnesia....
How does it feel to be on the recieving end & not the sending end as you incessantly insulted & attacked me personally AFTER I helped you fix your TV ????
Not so good is it....
If that wasn't enough for your ego problem , you had to follow ME to other threads & add your dumb-ass comments trying to goad me again....
NOWHERE in ANY of my posts in your thread or the others that I was helping at the time did you see me ask for a moderator !!!!
Now , after a mere 2 posts , you , being the sissy-pants that you are , are looking for a moderator...
So , as I said , go ahead & get ready...
The part that I really had a good laugh about was when you gave "your advice" to another poster who was also having a convergence problem....
That came across as you being knowledgeable , which I KNEW you weren't....
So you tried to be a "Tech" here & failed....GOOOOD !!!!
Not so easy , is it ???
Remember this & REMEMBER it well;...I did NOT start this......
IF you were SMART you would have NOT done this;=>...
I posted your name and asked you not to comment because I knew you would go in this direction.
In case you don't remember (& I know you DON"T) , I did NOT reply in those threads you stalked me in....
YOU want a fight & YOU got it...
BTW;...
I HAVE the manual you want....
You want it , go BUY it someplace....HAHAHAHAHA !!!!
Ron.M....Cool....
(This post was edited by Ron.M on Dec 20, 2010, 1:16 AM)
Dec 20, 2010, 3:47 AM
Post #10 of 12 (3090 views)
Gus67;.....
in any case,I just want to see if someone has a PDF of the manual to save me the $16 purchase before I decide to junk the TV and get a new one.
Cheapskate !!!!
If the TV is not worth a $16 investment from you , then just roll it out to the curb & let someone else have a shot at it .....
How's that for a "positive" comment ????
Basically what I am getting at is,Ron,are you going to go away or are you going to continue?
I haven't decided yet....
Am I wrong in assuming this guy is ruining a potential thread that could help others and allow this forum to do what it is here for,that being helping people repair their televisions?
Now you are playing the "sympathy" card for the moderator....
Tact & diplomacy are not in your vocabulary , is it ????
Ron.M....Cool...
Dec 22, 2010, 7:30 PM
Post #11 of 12 (3080 views)
Gussie.....
This is for those of you that may have missed the other 3 threads this clown started....
Guess what Folks !!!
I found a pix of Gus AFTER his corrective surgery to improve his appearance....
Here it IS:=>..
That explains his "charming" personality" doesn't it ???
Santa WILL dump a giant load of bat dung in your stocking , so have a terrible Christmas , and a lousy , sickly & poverty stricken New Year , DipS#!% !!!!
HA , HA , HA.....
(This post was edited by Ron.M on Dec 22, 2010, 11:05 PM)
Gus67
Dec 22, 2010, 9:46 PM
Post #12 of 12 (3074 views)
I know you are,but what am I?
