RCA 52
medicsanders
Nov 16, 2008, 1:17 AM
Post #1 of 6 (3625 views)
RCA 52 Can't Post
I have a 52 inch RCA... It is about 2-3 years old. The other day, when I turned on the TV, I had 3 lines (red, freen, yellow) that run across the tv. Also, the things that are on the TV, are shadowed.
Any ideas as to what is going on??
Please help.
slinteriors
Nov 20, 2008, 12:09 AM
Post #2 of 6 (3601 views)
Re: [medicsanders] RCA 52 [In reply to] Can't Post
Can you post a picture of your screen and also include your model number of the set. Sounds like an ITC222 xhassis with the FL231 open due to the vertical IC solder, but a pic would help me be more positive.
pfryejr
Dec 10, 2008, 10:48 PM
Post #3 of 6 (3557 views)
Re: [slinteriors] RCA 52 [In reply to] Can't Post
i have an rca 52" tv. model #hd52w59. and the chassis # is itc222a. just went out of warrenty in feb. and now i get the red blue and green on the screen. it looks like everyone has 3 heads. the screen aslo goes in and out. please help
slinteriors
Dec 11, 2008, 4:01 AM
Post #4 of 6 (3548 views)
Re: [pfryejr] RCA 52 [In reply to] Can't Post
convergence power supply board if all 3 colors are out thats the board on the left looking in from the rear which is suspended above the rest of the chassis
Apollo
Jul 22, 2009, 7:39 PM
Post #5 of 6 (3251 views)
are you getting the blinking lights in the front of the TV,if you are then your problem is most likely going to be a issue with your ballast, if your not getting the blinking lights then its most likely going to be a problem with your power supply board, there is a power outage in the board
rolandxman
Apr 28, 2010, 3:14 PM
Post #6 of 6 (2935 views)
Re: [Apollo] RCA 52 [In reply to] Can't Post
I have RCA HD52W58 52" TV. Starting a couple of months ago, when i tried to turn it on, it would shut down within a few minutes. After a couple of tries it stayed on. As of last night, it makes a high pitched whine and won't turn on at all. The green light turns on and the high pitch whine cycle like this for a few times by itself, and then stops. The TV never turns on.
