RCA Convergence Problem
matthewst
Aug 4, 2010, 5:41 PM
Post #1 of 11 (2825 views)
RCA Convergence Problem Can't Post
RCA
p46810lv
ptk195aa
The picture is "bowed in" at the top and bottom, and the colors don't line up. We used to just turn it off and on again to fix the issue. That trick hasn't worked for some time now. I've done a bit of research and believe the problem is one of convergence. I have two questions:
1. Does my model of T.V. have a service mode?
Service Mode http://en.allexperts.com/...n-TV-Convergence.htm
2. If not, or if service mode does not help; Do I need to buy a convergence chip/circuit thing and have a friend swap it out or am I better off buying a complete convergence board?
2A. Part Numbers?
matthewst
Aug 4, 2010, 5:42 PM
Post #2 of 11 (2822 views)
Re: [matthewst] RCA Convergence Problem [In reply to] Can't Post
Also, I tried the "Search" feature on this forum but kept getting an error.
Aug 4, 2010, 5:51 PM
Post #3 of 11 (2818 views)
STK730-130
See:
http://www.tv-forums.com/...string=ptk195;#55601
Same/similar has been asked/answered quite a few times in the past...
People should really learn how to USE their search & edit functions!Shocked
112 results when "PTK195" is search string.
Stay out of service menu!
(This post was edited by jts1957 on Aug 4, 2010, 5:54 PM)
matthewst
Aug 4, 2010, 6:02 PM
Post #4 of 11 (2814 views)
Re: [jts1957] RCA Convergence Problem [In reply to] Can't Post
Thanks for the reply! So if I'm understanding correctly I will need to purchase 2 STK392-040's if I can't fix my issue via "service mode". Is that right?
Aug 4, 2010, 6:09 PM
Post #5 of 11 (2812 views)
People really should learn how to read the thread (and any links contained therein) they are directed to. Doing so should clear up.
Edit: I just re-skimmed through them. Reading both WILL answer ALL your questions.
(This post was edited by jts1957 on Aug 4, 2010, 6:21 PM)
matthewst
Aug 4, 2010, 6:32 PM
Post #6 of 11 (2804 views)
I apologize for my noobness. I am just triple checking everything cause money is a little tight right now (school clothes) and T.V. repair is brand new to me. Thanks again.
matthewst
Aug 4, 2010, 6:52 PM
Post #7 of 11 (2800 views)
That's what I get for speed reading. One STK730-130 should do nicely. Wink
Thanks.
matthewst
Aug 6, 2010, 2:16 PM
Post #8 of 11 (2780 views)
Okay, so my T.V. does in face have that hidden menu. I accessed it and changed some of the settings. Specifically P4-P7. It didn't help. so I exited the menu and turned the T.V. off. Now (when powered on) I have sound but no picture what so ever. How do I get back to factory defaults or will the new STK reset everthing?
Aug 6, 2010, 6:10 PM
Post #9 of 11 (2774 views)
matthewst;.....
WHAT part of this did you NOT understand ?????
From jts1957;=>...
You now ,more than likely , have a 46" paperweight OR a 46" doorstop.....
If you come here for advice & help , why not LISTEN to & FOLLOW the advice that the experienced techs here give you for FREE !!!!....
If you don't & you turn what could have been a good TV into junk by NOT doing as we say , then you DESERVE what you get as an end result....Mad.....
Nice going.....Frown....
Enjoy your 46" RADIO !!!!....Unsure.....
NO , the new STK will NOT reset everything....PERIOD....Unsure....
Later....Ron.M....Cool.....
matthewst
Aug 6, 2010, 7:28 PM
Post #10 of 11 (2770 views)
Re: [Ron.M] RCA Convergence Problem [In reply to] Can't Post
Wow...:blasted: Well thank you all for your help and advice.
Aug 6, 2010, 7:42 PM
Post #11 of 11 (2770 views)
You dood it to yourself.
