RCA D52W20
mrd314861
Feb 28, 2011, 10:44 PM
Post #1 of 5 (7400 views)
RCA D52W20 Can't Post
I asked the experts at JustAnswer and no one had any useful info for me. I'm hoping someone can point me in the right direction.. Which circuits I should check, etc.
rca d52w20 itc222 chassis has blurry picture, images appear dark and smeared from the left side of screen to right. convergence seems ok, and is adjustable in all directions, but when setting convergence, the vertical lines appear very blurry and they are so dim you can hardly see them. Images are almost shadowed with a slight double-image to the right. The blurriness appears in all inputs as well as the on screen menus.
Optional Information:
Make: rca
Model: d52w20
Already Tried:
reflowed solder connections @ flyback & others, reflowed connections on ssb, checked fuses, visually checked all capacitors and cables, adjusted convergence, adjusted picture settings in service menu, adjusted focus pots behind front panel, tried adjusting crt lenses
Here's what I see on all menus and inputs. I know the convergence is off right now, but in the multi-point I can get it pretty close. The geometry on the right side of the screen does seem a little off, but unless that's part of the problem here, I'm not worried about it. Below, is the convergence adjustment screen (showing only horizontal lines.) If you look closely, you can see that there's vertical lines, but they are extremely dim and blurry. I'm assuming they should be as bright as the horizontal ones.
Another menu shot.
I went over all the boards to look for bad connections or burnt components. I found this ic on the convergence board that looks like it has been replaced since the printing on it is different from the others on the board. You can see that the board is burnt up pretty badly under one of the contacts, but it has no lead coming off of it. Maybe chip is bad?
This is just a component that has been resoldered or replaced. I ohmed out connections and they appear solid. Maybe it was replaced with the wrong one?
The only other thing I can say as far as symptoms is that the picture takes 10-15 seconds to come on after you power up the set. I'm not sure if that's normal or not. I was also having a problem with intermittant shutdowns and then the led blinking 3 times when trying to turn it back on. I resoldered the connectors on the ssb and that appears to have solved the problem. The screen was blurry like this before I did any work to it though.
richpart
Mar 10, 2011, 3:39 PM
Post #2 of 5 (7373 views)
Re: [mrd314861] RCA D52W20 [In reply to] Can't Post
Technical Information
Television Service Bulletin
TV-06003
DATE: 12/8/2006
Chassis: ITC222
TOPIC: Ribbon Connectors, Intermittent faults
Symptom: Intermittent shutdown, Error Code 33, Convergence Errors, Miscellaneous Faults
Cause: Deformed Ribbon Connectors
Cure: Replace Connector - RCA Stock #258686
In ITC222 based TVs manufactured between serial number range G13XXXXXX and G26XXXXXX, Power Supply
Deflection connector, BP005 (Figure 1), and Convergence Module connector, BW005, have been found deformed.
The deformity results in inadequate pressure applied to various contacts of the inserted ribbon cable. Depending on
the contacts involved, this defect will result in random faults such as intermittent shutdowns, Error Code 33,
convergence issues, dead set, etc.
Although there is a possibility of deformed connectors in other LOT codes, Power Supply Deflection modules marked
with LOT # NNA600020A and Convergence Modules marked with LOT # NNA600011B are highly suspect. The LOT
number may be found on a white sticker just above the barcode label on each module. (Figure 2)
Knowlege is King Baby!!!
Repair man
Mar 12, 2011, 6:02 AM
Post #3 of 5 (7357 views)
Hope I'm not steering you in the wrong direction but I think there is a cap that may be bad somewhere near where the yoke plugs connect to the sweep board (the vertical yoke wires; usually yellow & green). It may be a small rectangular cap I can't remember. I'm sorry I can't give you more accurate information it's been approx 4-5 years since I've worked on a set with this problem but follow the vertical wires & see where they lead.
Learn Plasma TV Repair
_________________
Learn LCD TV Repair
mrd314861
Jun 14, 2011, 12:20 AM
Post #4 of 5 (6653 views)
Hoping somebody can shed some new light on this one. It's been a few months and I still haven't made any progress with this problem. I'm really hoping someone has an idea, or I'm going to toss this thing.
Thanks!
Jun 14, 2011, 12:56 AM
Post #5 of 5 (6652 views)
When in doubt ... "C-4!"Wink
