RCA PROJECTION PROBLEM
MC
Oct 13, 2005, 12:24 AM
Post #1 of 3 (1849 views)
RCA PROJECTION PROBLEM Can't Post
I RECENTLY PURCHASED A RCA PROJECTION CTC195 WITH A MAJOR CONVERGENCE PROBLEM! THE PIC COMES IN PERFECT AT FIRST THEN AFTER A MINUTE OR SO IT GOES WAY OUT OF ALIGNMENT AND PULLS IN FROM THE CENTER OF THE TOP AND BOTTOM. MENU ADJUSTMENTS DO NO GOOD . ANY HELP ON FIXING THIS WOULD BE GREAT! THANX,
MC
dontvvcr
Oct 15, 2005, 9:07 PM
Post #2 of 3 (1822 views)
Re: [MC] RCA PROJECTION PROBLEM [In reply to] Can't Post
Remove back on your left will be the main board on right will be your convergence board right above is the power board for the convergence remove it and you can try to resolder it being very careful in not causing any solder bridges.But it's more likely the IC STK730-130 is failing just replace it and you should alright.Dontvvcr
probuilt
Oct 16, 2005, 7:14 AM
Post #3 of 3 (1817 views)
Just like "dontvvcr" says, it is most likely the convergence ic's. They can over heat over time and cause connection problems. Sometimes they can be solved easily with a simple resoldering of the contacs, other times they need to actually be replaced. If you have come to the conclusion that they need replacement, try here www.audiolabga.com Enter the part number found on the STK ic (usually mounted to the large aluminum heat sink). Also try www.fixyourowntv.com for helpBlushBlush
Aslo, you might be interested in earnig a new tv for free
Copy and paste this on your browser to get a Flat Screen for free
http://flatscreens.freepay.com/?r=23486733
Just ask "Mel" he did it too. Learn from the Pro's
