MaierTV
Jun 9, 2003, 11:51 PM
Post #3 of 3
(10025 views)
Re: [chuckie] RCA PROJECTION TV
Well Kevin gave us a model # to work with Kevins most likley only needs the high voltage spliter replaced, I do a little more than that, but kevin you could try this, remove the speaker grill, remove the front panel, do not disconectt any wires then on yore right you will find a black box with several wires leading to it Carfully remove the one with the RED eend on it, try to pull this as far out of the set as you can, keep it away fromm meatel or any other componets as you can, isolate it by either black tape or ( tollet papper tube with the bare end of the wire 1/2 way thu) then.............plug it in with the antena attached, if then the st starts and has audio ( there will be no PIX) your splitter is bad
