mikemaiertv
Jun 10, 2005, 4:48 PM
(1921 views)
Re: [timmyyy] Rear projection Burn-in
First thing you got to think about what you want to do,,, If you display a all white signal it is true you will burn all three tubes however the ESPN logo will also burn at the same rate , so when you are done now all three tubes will be burned and the spot you tryed to get rid of will now be darker, So doing this is a real bad idea, somewhere right neer the front of the owners manual, in small print is a warning never to let a image stay in one spot for to long or this will burn the crt's, and that is not covered by any warntee, now when people buy there band new 16x9 wide screens and dont like havine everything short and fat like the wide mode shows they start running the set in the standerd mode with jail bars on the sides, well this also will burn the jail bars in, the wonderful network folk with there dedicated logo that never moves or change colors now there burning the logos in to there viewer set but they could care less, afraid the only fix for this is to replace the crt's Mike Owens Owner Competition TV Spokane WA.
