Nov 1, 2010, 1:01 AM
Post #12 of 17
(6104 views)
Re: [speedracer0626] Service Menu
speedracer0626;..... The question I have is would scratches on the fisheye cause issues? I read about what you did to the blue fish-eye lens in one of the other threads.... Answer is ???? Depends on how bad , how deep , how many , how close together they are & how wide a scar there is.... IF they are mild , chances are that you probably wouldn't see anything in the pix... I think it would be fixed by following the directions in your post, NOOOOooo , NOOoooo , NO !!!! My "helpful hint" ONLY is for;=>.... The blue cross will move fine up and down, but when I push it to the right it only goes so far and it lacks maybe a 16th of an inch from reaching the white cross. Scratching of the lenses will cause a blurring of the pix in ONLY the areas of where the scratches are.... NOT a convergence issue.... From the looks of the pix you posted (A tad blurry) , the centering rings on your TV look like they are made of steel.... IF you take a close look at yours , see if they are... IF so , you should be able to move them with moderate effort without fear of breaking the ring's tabs.... BUT , use care , as you can break the plastic tabs holding the rings in place...... After you do this , go back into the "CUSTOMER MENU" convergence adjustments ONLY & touch up the blue convergence adjustments... That should take care of it... Good Luck...... ..... PLEASE let us know how you did.....OK....THANKS.... Later...Ron.M.... .... Veteran & Retired TV technician
