dude998866
Oct 6, 2008, 6:03 AM
Post #4 of 7
(3191 views)
If your TV shuts down when plugged in, characterized by the blinking red standby light, it means that there is an internal fault. Most likely an open circuit. By far the most common culprit are the Convergence IC's. Sometimes it's just a cold solder joint so simply re soldering the two IC's will solver the problem, other times they must be replaced. When I did mine it was just a cold joint so it's worth checking
