WIERD PROBLEM
afterburner1
Apr 9, 2009, 3:52 PM
Post #1 of 6 (2582 views)
WIERD PROBLEM Can't Post
OLDER TV, ANY OF HITACHI MODEL: CU 5001, CU5002, CU5003, AND CU4601 has developed the following problem:
The symptoms are: When the set, CU 5001, is turned on, the screen remains black for about two minutes or longer. It then developes an incomplete picture on the top of the screen that slowly, and in perfect sync, travels down the screen until the screen is completely filled. It is similar to somebody slowly drawing a shade down the screen that has a picture on it. During the period of a black screen there is sound. The TV will then continue to function perfectly for hours.
I know the TV will eventually fail, and would like to effect a repair before there is a total failure. Would appreciate some hand-holding on identification of the board and component, if possible.
Thanks
Afterburner
Apr 10, 2009, 11:51 AM
Post #2 of 6 (2575 views)
Re: [afterburner1] WIERD PROBLEM [In reply to] Can't Post
try changing all the electrolytic capacitors around the vertical scan ic and also resolder all pins on the ic as well
afterburner1
Apr 12, 2009, 12:38 AM
Post #3 of 6 (2565 views)
Re: [techchris] WIERD PROBLEM [In reply to] Can't Post
Thanks Chris; will breakout the old soldering weapon. I know the electrolitic caps dry up over the years. I just really like this set and want to keep it going! Thanks again
Afterburner
Thriftywife
Feb 8, 2010, 2:37 PM
Post #4 of 6 (2398 views)
I have a similar problem. I have a Hitachi rear projection TV model 46EX2K, Nov '92.
We had a freeze in our area, ever since then, the picture has that window shade effect, except mine "rolls up" half way turning to a black screen from the bottom. The top half is just fine.
Me being the walking disaster that I am, decided to take the back cover off and get out my blow dryer. I found when looking into the rear of the TV, in the lower left corner, there is a gold rectangular "box" with a whole lot of too many wires coming out. When I heat that "gold box" up, the "screen" immediately rolls back down to a perfect picture. Unfortunantely, it wont stay. As soon as it cools, maybe 1-2 minutes max, the screen "rolls back up" to black.
Does anyone know what kind of repair I'm looking at and an approximate cost?
Thank you in advance.
robertlanham79
Apr 10, 2010, 8:18 PM
Post #5 of 6 (2299 views)
Re: [Thriftywife] WIERD PROBLEM [In reply to] Can't Post
i hope that by me responding this post will be put back at the top of the forum and MAYBE some one will reply something helpful[;)
Thriftywife
Jun 22, 2010, 11:21 PM
Post #6 of 6 (2216 views)
Re: [robertlanham79] WIERD PROBLEM [In reply to] Can't Post
Thought I'd update. Never figured out solution to this, so bought a new one. Put this out on curb (with remote and manual) and someone took it. Hope you had better luck After and Robert. Wink
(This post was edited by Thriftywife on Jun 22, 2010, 11:22 PM)
