docdave
Jun 2, 2006, 12:38 AM
(1200 views)
ctc195 conver menu
just when i thought i had seen all the prob with this chassis model on this set . in the on screen menu when i go to the screen menu for this projection tv i should have 4 things menu lan , source type number 4 should be ajust projection tv for static convergence no number 4 just 1,2,3,0exit changed eprom and pross. for exact model from my rca parts place in milwaukee took out a eprom from a none working one just to see if bad eprom same thing put new eprom in working cube works ok. never needed a chipper checker before after 35 years in this field any one run into this before . also found the elusive audio problem on this set that rca has a prob with . only because it acted up on my bench one day will post later dont have smd diode info infront of me
